MrWizard
Sep 10, 2017Moderator
your diesel generator puts out 110v
just like shore power, the utility company at home
it is the charge converter or ( inverter-converter combo ) does the battery charging
battery voltage dropping means NO charging
blown fuse ?
bad unit ?
tripped circuit breaker in the breaker box OR on the unit ?
equals NO 110 to the device so it does not have power to charge your batteries
we are not clairvoyant , we can NOT see your equipment
you need to answer the exact questions, not in direct guestimations
does your air conditioning run, your MW work
your answer about (1) item plugged in
sounds like you tripped a breaker and the (combo-inverter-ccharger) is now using invert mode to make 110 on the outlets, and it is using your batteries instead of charging them
please post
make model year of RV
make model of inverter or converter
blown fuse ?
bad unit ?
please post
