tenbear
Nov 17, 2014Explorer
Joe417 wrote:
It may be more accurate to install the shunt in the positive leg of the battery.
The same current flows in the negative and positive lead. It is better to put the shunt in the negative lead since puting it in the positive lead requires running 2 small wires carrying the full 12v to the meter. Of course, if you really want to, you could put a fuse in both meter leads.
My ammeter is installed in the negative lead.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
