pc500
Nov 20, 2014Explorer
christopherglenn wrote:
I always try to put shunts (amp meters) in the positive lead, there is almost always more then one ground path. The converter 12 volt ground may be grounded through the AC ground as well. There may be leakage in the fridge and water heater circuits to ac ground also - usually these would trip a shore power gfci.
Which ammeter do you have that works?
