โAug-27-2014 06:43 PM
โAug-31-2014 06:32 AM
โAug-30-2014 03:42 PM
Handbasket wrote:
The battery has _nothing_ to do with it as long as it will start it. You're seeing either a failure in a safety like the low oil switch or a failure to produce voltage.
These 2800 Onans (I've owned 3) get the starting ignition current from the battery while cranking, but change over to self-generated power when the start switch is released.
Both of my similar failures have been failure to produce voltage; once under warranty, it was the rotor/stator, the other time it was the voltage regulator. Fairly easy to diagnose with the service manual and a volt-ohm meter. There's also troubleshooting steps at the Flight Systems website.
All 3 of mine were built after they deleted the low oil switch. Not sure about yours. If you have it, it's a possible source. Also be sure you're checking the oil level the right way. For all of mine, after wiping the dipstick, it's to be rested in the lip of the hole, _not_ screwed in. If you read it after screwing it in, you are always low on oil.
Good luck with it. They can be dang frustrating.
Jim, "Instant human, just add coffee."
โAug-29-2014 04:50 AM
โAug-28-2014 06:34 PM
โAug-28-2014 04:43 AM
โAug-27-2014 08:11 PM
โAug-27-2014 07:11 PM
โAug-27-2014 07:10 PM
