So the new TT has an outside kitchen and 115VAC dorm fridge. If I'm using the fridge I assume the access door for the kitchen must be open to ventilate the fridge?
You need to check for vents behind the refer. Some OEM's did NOT vent that cabinet and the refers overheated and failed. Most, now, vent them to allow them to run with the outside door closed. NO VENTING internally, then you need to run with the outside door open. Doug
