Outside light switch on a hilo
scottsnider
I just got a 2004 22t Hilo trailer and everything seems ok but I can't find the switch for the outside light, does anyone know where it might be hiding?
4 REPLIES 4
scottsnider
Thanks for the info, I found it under the cabinet as mentioned. Funny I had a trailer that was the same way and forgot to even think to look there, again thank you.
drsteve
Should be right by the entry door.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
rrupert
I agree with the switch location. You should, if you haven't already, join the Hi-Lo Trailer Forum:Hi-Lo Forum There are nearly 11,000 friendly members there ready to help you with your Hi-Lo questions.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
red31
mine, '88, is under the cabinet nearest to door. Bottom of cabinet.
That would be the cabinet above the lift switch or the cabinet to the rear of the door.
