Pair of Yam EF2000is to run roof AC?
merc1100sc
I know similar questions have been asked over and over again. Mostly about running an AC off one 2000 watt unit.
I have a 28' work and play with a rooftop unit. Not exactly sure of the AC specs. I have two Yamaha EF2000is inverter generators that I plan to use to power the camper. Will these two, bridged together, run the AC, lights, etc. with causing harm to the generators or any any electrical components?
Thanks.
12 REPLIES 12
SoundGuy
merc1100sc wrote:
I suppose once summer gets here I should try the AC along with other devices I may be running and see how it goes. The only other major draw I could see using at the same time is the microwave.
There's absolutely no need or reason to subject your genset(s) to significant load by running any more than one high load device at any given time. It's called power management - if the A/C is running when you want to use the microwave for a few minutes just dial back the A/C thermostat so the compressor kicks off and remains off while you're using the MW ... same approach we used when my wife wanted to use her hair dryer. If I were in your shoes I'd sell one of those EF2000iS gensets and use part of the proceeds to add the aforementioned Micro-Air Soft Starter Kit to the A/C which will allow it to run on just one EF2000iS. K.I.S.S.
2012 Silverado 1500 Crew Cab
merc1100sc
Thanks. I suppose once summer gets here I should try the AC along with other devices I may be running and see how it goes. The only other major draw I could see using at the same time is the microwave.
Thunder_Mountai
Yes, your paralleled Yams will run the AC and other items within reason. The only additional thing I would add is that when camping at 10,000 feet my paralleled Honda 2000s struggle with the AC if I add either the microwave, coffee maker or toaster oven. Because of loss of power at altitude, it takes both of them to run just the microwave.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
merc1100sc
Wow. A lot of info. How do I know if I have this Profressive Industries thing?
SoundGuy
bob213 wrote:
Both Honda and Yamaha have problems with the Progressive EMS unit. I believe the EMS sees an open ground.
Of course, but interpreting the genset's floating neutral output as an open ground has nothing to do with Progressive's Yamaha EF2000iS disclaimer ... read it and it's obvious Progressive is convinced the EF2000iS's waveform which can become irregular under certain conditions will destroy any of their EMS units, thereby voiding the Progressive EMS lifetime warranty.
bob213
Both Honda and Yamaha have problems with the Progressive EMS unit. I believe the EMS sees an open ground. This can be solved with a neutral ground bonding plug inserted in either generators 15amp outlet. It's just a plug with a jumper between the neutral and ground posts. neutral ground plug
A Suppco hard start capacitor will help but the two genies should be able to do it on their own.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
SoundGuy
GordonThree wrote:
A single Yam will not start the rooftop, nor will the parallel configuration running in Eco mode.
Probably would if you were to equip your A/C with a Micro-Air 364 Soft Starter, as reports from Honda EU2000i owners say it absolutely does work.
GordonThree
I have two Yammy ef2000's and the genuine Yam Twin Tech cable. The parallel configuration would not reliably start my 13.5 rooftop until I installed an aftermarket start capacitor on the rooftop.
After installation of the cap, the parallel configuration will start and restart the rooftop no problem. A single Yam will not start the rooftop, nor will the parallel configuration running in Eco mode.
1320Fastback
I have two of the same gens and the Yamaha Sidewinder parallel adapter and it powers the AC on my 2015 SandSport just fine.
I've read the new V2 have a much cleaner sine wave for sensitive electronics.
Being a mechanic I must say these gens are very easy to work on as far as carburator cleaning. Pop the back cover off, remove the air filter housings it, remove the studs that hold the carb to motor, clean and put back together. Probably a 10 min job once you've done it.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
SoundGuy
Be aware that the Yamaha EF2000iS doesn't play well with any Progressive Industries EMS as detailed in this disclaimer so if you're protecting your rig with one of these units you'd want to remove it from the circuit before powering your rig with these gensets. Can't say whether Yamaha has solved this issue with their newest version of this genset, the EF2000iSv2. If you don't use an EMS while running on shore power (a mistake IMO) then this wouldn't be an issue for you.
bid_time
Nomad II
Nomad II
Well assuming your RV is not more than 30 amp, and the yamaha's can be paralleled, and the generators are rated for 1800 watts each continuous, then yes.
