Freightguy's avatar
Freightguy
Pawer gear fault and failure. Anyone ever have this happen?
THis is in my 2009 American Tradition 42P.
So the other night I overnighted in a parking lot and leveled the coach on air and not the jacks.
In the morning when I was going to leave I started the coach and pushed the travel button. THe travel and HYD lights started blinking and I could hear the pressure switch in the bay with the leveling system compontents screaming. I turned the rig off and started over but this just happened again. After 5 minutes the pressure switch stopped making noise and I also have the fault light come on.
I was able to get the coach into travel mode and make it to my destination however I still have the issue. I contacted the manufacturer LCI and they told me the fault I have is the system thinks the jacks are down. They told me to unplug the pressure switch as that might clear the fault. If not to use a jumper wire to open the circuit. I have done both with no luck. I have an email to LCI now letting them know. But I wondering if this happened to you and ho did you fix it. Thanks,
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
