โMar-15-2015 12:40 PM
โMar-26-2015 04:17 PM
โMar-26-2015 02:01 PM
SNOMORE wrote:
As for the converter - Actually, a easy solution for this is to install a simple 120v 18A relay from Amazon with "Normally Closed" contacts. Link to Amazon part is below. Costs less than $8. Got a pre-stripped lamp cord from Walmart for $3.50 and plugged it into the inverter and use it a to energize relay coil. and then switched the black wire on the converter outlet via the relay so that when the inverter is on, converter is off.
Amazon Relay
โMar-26-2015 01:25 PM
โMar-17-2015 03:36 AM
CaptSailor wrote:
I run the generator in a small generator shed. So I will mount the transfer switch in there, making the hookup simple.
โMar-16-2015 08:04 PM
โMar-15-2015 02:49 PM
โMar-15-2015 01:28 PM
โMar-15-2015 01:20 PM
smkettner wrote:
Transfer switch has two input and one output. Connect the inverter to one input and the main cord to the other input. The output goes to the distribution center. Wiring diagram should have been supplied with the switch. Plug the cord into the generator.
Yes the solar direct on the battery is independent and no change needed.
โMar-15-2015 01:03 PM
