Brettmm92's avatar
Brettmm92
Planning to make outdoor shower with 55 gallon barrel
As the title says, I'm very interested in an outdoor shower with water heated by sunlight. I have a nice black plastic 55 gallon barrel with a removable, locking lid and some space to put it. I'm willing to take some time and money to make this more than half assed. Does anyone have any ideas or inspiration? I also have a smaller, 8 gallon bucket but I'm thinking there wouldn't be enough water and a 55 gallon could retain heat better as it gets colder. This project has a blank slate so far but I'm hoping to eventually get it so it has one of those nice big "sunflower" like shower heads. I have never used one but I feel like showers with a pull string (like a ceiling fan) exist and would like to use that. The main question I have is what piece to look for to establish the plumbing on the barrel. Specifically, I'm going to make a hole in the barrel so the piece that connects to the barrel (and ends up becoming a showerhead) has to have two bigger pieces on the outside and inside of the barrel. For example, when you drill a hole for a bolt you sometimes use a washer on each end to compensate that the bolt is smaller than the hole. And a recommendation on materials would be great.
Thanks ahead for your time, all input is appreciated!
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 25, 2025
