RobG's avatar
RobG
Pop goes the water heater!
I had a new water heater installed back in 2014. It popped two nights ago. I got up to the sound of water -- I actually thought it was raining. Upon closer inspection, it was water pouring out of my water heater. It made quite the flood outside.
I shut off the water to it, and got a flashlight. The "tunnel" where the burner goes is all rusted out and collapsed. Despite ensuring a good anode rod, it appears that corrosion did the thing in.
So now I have two choices: Replace it with another one, or go with an on-demand system. Cost is similar: About $500 for either. The on-demand system that people seem to be recommending is the Girard 2GWHAM. The water heater I'd use is a Suburban 10- or 12-gal unit. The trailer came with a 12-gal, but it got replaced with a 10 in 2014 (which I didn't know until yesterday; I thought it was another 12).
In the meantime, I'm showering in my camper. Thankfully I have that as an option.
Any suggestions? Any other (cheaper hopefully) on-demand units I can consider?
Thanks.
Rob
Having RV issues? Connect with others who have been in your shoes.24,214 PostsLatest Activity: Mar 14, 2025
