โFeb-15-2019 06:58 AM
โFeb-16-2019 02:33 PM
โFeb-16-2019 01:57 PM
โFeb-16-2019 01:40 PM
โFeb-16-2019 01:26 PM
โFeb-16-2019 11:54 AM
JusBud wrote:There are a few posters who get very confrontational when told that their ideas don't match what you want. They apparently feel that the way they do it is the only way to do it, and you must be stupid if you disagree. They sometimes have some good advice, but they rarely inform without preaching.
Thank you MrWizard
I have a campbell hausfeld 80 amp for 20 years also.
It works and I even welded some fence around the house
But it's heavy and only adjustment is wire speed
I've welded for over 40 years. Mainly stick.
Not sure why you're getting so defensive and judging me without knowing me.
I didn't know what I wanted when I posted and wanted to get some ideas. The original 2 welders I was considering isn't what I want.
After doing some research the DC inverter welder is exactly something that fits my needs and wants.
Not sure why that's so bad.
It's compact, lightweight, and has amp and wire feed settings and it doesn't break the bank.
Your final quote was totally unnecessary.
"Stupid is what stupid does" - Forest Gump..
When someone stoops that low then I have no reason to listen to what you have to say and you lost all credibilty
โFeb-16-2019 11:15 AM
โFeb-16-2019 11:05 AM
โFeb-16-2019 10:05 AM
โFeb-16-2019 08:37 AM
JusBud wrote:
So you're not a professional welder and yet I don't know anything at all and I'm supposed to listen to you?
Got it.
Let me rephrase and repeat my original post.
I don't want to use gas.
I don't want to look at the bigger picture.
I'm looking for a portable compact welder to get by in a pinch as I stated I have a friend that can fix it right when I get home.
I'm not starting my own business nor will I be welding everyday.
I don't want to spend $1000+
If someone comes here and asks about getting into a basic rv do you tell them to just get a Newell or Prevost?
โFeb-16-2019 07:48 AM
โFeb-16-2019 07:08 AM
JusBud wrote:
I'm not looking to build a Golden Gate bridge.
I also drive a 13 year old rv by a manufacturer that went out of business but it serves the purpose for our intended use.
I'm looking for something for the occasional repair and I can bring it to my friend when I get home who has all the right stuff.
โFeb-16-2019 06:55 AM
Gdetrailer wrote:JusBud wrote:
Decided on a DC inverter welder
The Century FC90 has good reviews and priced right
Half the size and weight that i currently have
FC90
Tractor supply has something similar but 140amp
Probably not worth the extra money for what I need
140 amp
What utter garbage..
Do yourself a HUGE favor and buy a REAL welder up front the first time, then you will never have to revisit finding another one..
Something like a Millermatic autoset..
Millermatic 140A Autoset..
That pix is what I bought quite a few years ago after banging my head against the wall which inferior cheap garbage MIGs.
Hands down the autoset feature WILL make your life easier.
In auto set mode, you simply set the dial to the metal thickness and it will automatically set the current output AND the wire feed speed to the proper settings.
No joke..
I have no issue welding SHEET METAL with the autoset, don't try that with those cheap welders.
Do yourself another HUGE favor, do not bother with self shielding wire and get the shielding gas, your welds WILL vastly improve..
Not sure if that model is still available
I believe they may have replaced my model with this one..
Millermatic 211 which may be an inverter version..
Expensive, yes, but well worth doing right the first time instead of beating your head against the wall..
โFeb-16-2019 06:46 AM
โFeb-16-2019 06:09 AM
