Power Issue,s
GeneRich
Do not know what happened but in my bathroom both lights (shower & sink) and the vent fan have stopped working. All three light bulbs were burned out and black. I have check the power and I am getting 12volts. But new light bulb will not work. Even switched out light fixture with a working one, still does not work. Fan is same way, power is there but fan does not work(couple mouth old vent fan). The only place this is a problem is the bathroom? All other lights fine.
Also have gone back to switch's, get same reading.
Fuse are good.
Battery good.
Also ask mfg. for wiring drawing.
2 REPLIES 2
GeneRich
Did some more checking, the grounds are good. Now working, I check the wiring at the DP and found all the main wiring connections a little loss.
Might need to put on every two year Maintenance list to check on.
After 10 years of heating up and cooling down I guess they must of work loss.
kaydeejay
Fuse are good.
Battery good.
Check for a bad ground. 12V does you no good if there is no return path.
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
