wa8yxm
Jul 29, 2021Explorer III
12 ga is 20 amp for less than 100 feet
30 amp and a long run 8 ga or larger is required
That is the issue
NOTE that sucking More amps by using an Autoformer to boost the voltage (By booting amps park side) can cause that 12ga to melt..> The park won't be pleased if they see you have an autoformer..
So,, Install it, inside where it can not be seen.
(That is what I did)
That is the issue
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
