pconroy328
Apr 13, 2023Explorer
MrWizard wrote:
I think he means look to verify broken or not,
Motors are available
Gear boxes are available
Replacing old motor with a new replacement version can also mean modifying the wiring, the last motor i replaced did not have the same connections as the one i removed, replacing the controller usually requires replacing the door sensor switch, because the controller circuit has changed to sense a different switch connection,
One is a switch that closes AKA when the magnet is near, one is switch that opens when the magnet is near, I'm not sure which one is the old design and new design,
I think closed when magenta is near AKA normally open switch is the old style, but i can't swear to that,
Anyway the controller is not the OP's problem
Yessir - you are correct. Another person told me the controller uses Current Sensing to determine when the motor has reached it's limit/end stop. So broken or worn teeth might be the issue.
It's a nice day today so I'll ruin it by crawling underneath the beast and yanking stuff off. :)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
