GordonH's avatar
GordonH
power to video switch
We have a 2005 HR Neptune and are having tv problems. We have a WINEGARD Video switch..model VS 0604/6412. I found a detached power connection which I have rectified. Two problems.. 1. There is no power leading to the switch. Can anyone tell me where a fuse might be? 2. WE never apply power to the video switch. Would the lack of power cause a poor display on the TV? Hope someone can help. Gordon.
  • Found the solution. I e-mailed Holiday Rambler. The tech told me to look for the fuse in the front bay under the driver's seat #10. Blown fuse....replaced.....four month problem resolved!!
    Thanks,HR!
    Gordon.
  • wa8yxm's avatar
    wa8yxm
    Have, on occasion found them marked with labels like "RADIO" but to be honest.
    Find the primary house fuse block, get a test lamp (This is like an ice pick with a light bulb in the translucent plastic handle and a wire with clip) clip the clip on a known ground and go tap tap on each and every fuse in the box (Tap/probe both ends one at a time)
    Dark/Dark fuse unkonwn
    LIGHT LIGHT fuse goood
    LIGHT dark or dark LIGHT, fuse bad.
    In the house block, dark dark should not happen (Does happen on the chassis block though).
  • You'll need to find a 12V supply for the switch because w/o power the "booster" function of the switch will not work and you will probably get poor TV reception.
    Read the manual (PDF).
  • Yes, lack of power would effect antenna booster. No power to booster.
    Look in exterior bin below the driver's seat area for fuses.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
