RV_daytrader's avatar
RV_daytrader
PowerMax PM3-35 vs Pro/Dyn PD4635
Need to replace my old 6300 converter...it works OK but only charges at 3 amps! The Progressive Dynamics PD4635 is an upgrade the would fit right in where old converter section is, but costs $200.....the PowerMax is a deckmount that I believe can be mounted close to battery, and it is $100 delivered....has any one upgraded with a deckmount converter and was it harder to wire in???...tia
I only have 1 group 27 battery and think a 35 amp charger should be enough.
  • No just flip the breaker off. In fact both chargers would probably work together just fine (BFL is the master of doing this), but at that low charge rate, might as well just turn it off and save it.
    Jim
  • HiTech wrote:
    If it works ok for you you can leave it in place as a backup and add a second one, or even use a good portable charger.
    Jim
    Jim...If I leave the old one in place, do I have to disconnect anything on the old one??
    Jim
    X2, you can leave the existing one in place and wire in the new one close to the batteries. I did that in my "old" 5er.
  • If it works ok for you you can leave it in place as a backup and add a second one, or even use a good portable charger.
    Jim
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
