RayJayco
Jan 07, 2014Explorer
DDmay wrote:
Rayjayco, I recently purchased a Keystone Cougar also and had the same problems. Disconnecting the battery switch is not enough to allow a reset. You have to disconnect the battery at the cable connection and let it sit for a few minutes. The dealer and I got tired of doing this and he finally installed a n updated control panel that I had contacted the factory about. It was an updated to 2014 "filtered" panel that looked the same as original, but was supposedly different inside. We have had no further problems, although we have not used it very long, 2 camping weekends, until colder weather set in and it is stored for the winter. This was a warranty situation and they did it within 30 minutes or so. Unscrew and unplug panel,then reverse procedure.
DO NOT BREAK TECH'S CONCENTRATION WHILE HE IS DOING THIS, there are lots of plugins.
For further, contact me, as names and phone numbers are in camper and it is stored for now. Below 0 here right now!
DDmay
Thank you! This seems to be the solution.
They would often arrive at the trailer at night and have to disconnect power and battery, wait a few minutes then reconnect, to have lights, open slides, etc. Not very good if you are tired, it is late and raining!
Stay warm!
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
