ajriding's avatar
ajriding
Sep 04, 2020
Propane leakdown
I put a pressure gauge inline between the tank and regulator for the first time ever.
After I shut the gas off the pressure on the gauge will drop overnight from green (pressurized) to the red (meaning low low pressure).
Should the pressure on the high side remain high for days/weeks or is it normal for that to drop? Im not sure if the regulator is venting it or if I have a leak after the regulator.
Nothing bubbles, but there is one fitting I cannot get to.
I used Nylog on every fitting.
3/8 copper and flare fittings.
There is only a space heater (has solenoid valve) and a stove.
I cannot detect any odor.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
