EagleScout-USA's avatar
Mar 29, 2021
Propane Pigtails
Good evening,
I have a 2015 Jayco 26BHS. A smell and soap test reveals leaking propane at each pigtail connection to the dual propane cylinders. The regulator is a Cavonga Group Double Stage Low Pressure Automatic Changeover Regulator. The factory line is Cavanga flexible hose with Back Check Max WP 350PSI Cat #2 18CE. Considering they have both failed, looking at an alternative replacement to that model is what I have in mind.
Assistance and guidance is needed in purchasing replacements. The current connector is not inverted. The opening at the end of the pigtail measures at 6/32 of an inch. A brass circumference of about 2/32 of an inch runs around the opening. This appears to be less than the visuals I am getting from the replacements that I am looking at. The holes seem wider. Inside of the regulator itself, there also appears to be a smaller opening that lines with the smaller opening on the hose. I was looking at options on Amazon; however, wasn't sure if there were negative implications of having a wider opening on the pigtail than the accepting opening on the regulator. I would appreciate any thoughts and direction. Heading out Friday morning, and didn't know I had an issue until just now. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
