MEXICOWANDERERExplorerAug 15, 2018Proper Wire Terminal For Oriental Terminal BlocksYou've seen them. Center screw with corrugated like flat tab washer beneath. Screw head uses that goofy straight blade phillips combo. I'm supposed to attach a pin to the largest wire that will fit...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
Related ContentHolding Tank TerminationsEVER HOT TERMINAL?Diodes between (-) terminals on parallel batteries. Why?Terminal Block with Circuit BreakersCan you use all terminals in parallel connection?
