MEXICOWANDERER
Apr 15, 2014Explorer
You may need to brush-up on basic battery maintenance which includes finding out voltage values. A cheap digital volt meter is your best friend. Newer breeds of vehicle chassis charging systems do not commonly fail in the "Voltage too high" mode, but you need to check it. Anything higher (at the battery posts) than 14.2 volts is wrong. Seek professional help. If voltage is normal your battery has gone bad.
