darsben
May 22, 2016Explorer II
Since when you are plugged into shore power your 12 volt stuff (fridge etc) is run of a built in converter my initial guess is that the wire you have that tripped the breaker went to the converter that supplies 12 volt to the rig. Now you are running only off battery.
My guess bad converter
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
