MDKMDK
Jun 05, 2020Explorer
pconroy328 wrote:
So I could use a "shove in the right direction."
My Solar is all DIY. Two 100 watt panels, an EPEver 30A MPPT controller. One group 27 (for now).
It's working. It's keeping the battery charged.
But I don't think it's working right, or even close to optimal.
The first 100 watt panel is two years old. I started with it, just one 100 watt. I added the second 100 watt panel a month ago - wired parallel.
Wire from panels to controller is 10g stranded from Home Depot.
Thing is I just started watching the power output recently!
Today is FULL SUN, No Clouds, Noon in Denver.
I'm getting 30 watts.
Looking back at historical data for the week, the best I've ever done is 85 watts from the two panels.
Does that happen?
I *am* plugged in and the battery is fully charged.
Is that what's happening?
The controller is smart enough to dial down the wattage since it's not needed?
If I unplugged and discharged the battery - will I see the controller display more wattage from the panels?
(As I'm typing this, I think I'll try that now. Unplug.)
But I'm a bit confused and wanted to hear from some of you.
Thank you!!!
It's how my Zamp ZS-30A PWM charge controller and 3 X 100W Sun Power panels work. The CC only sends what it sees as the demand at the batteries. Add a load, or unplug from shore, and the amps/volts numbers should increase as the battery discharges. BFL13's numbers are probably spot on, based on your set up.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
