BFL13
Jun 06, 2020Explorer II
If the Isc of a cell is 8 amps, which you get with no voltage load (Voc), and you short the pos and neg wires from the panel, would you not get 8 amps on the wires using a clamp meter?
A "shunt" type solar controller controls by turning the panel on and off by shorting it. A "PWM" controller and an MPPT controller when in Abs or Float turn the panel on and off rapidly--AFAIK by shorting it too.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
