โMar-03-2016 04:55 PM
โMar-08-2016 07:45 AM
โMar-08-2016 06:46 AM
smkettner wrote:
Morningstar does actually protect itself from high panel voltage.
The issue is that you get no power while in protection mode.
http://www.morningstarcorp.com/wp-content/uploads/2014/02/TSMPPTdsEng.pdf
โMar-07-2016 09:08 PM
โMar-07-2016 08:57 PM
โMar-07-2016 07:03 PM
โMar-07-2016 06:40 PM
โMar-07-2016 06:33 PM
Almot wrote:
Where did 45.5 VOC at 25C come from? For panels he considers it's 36V at 77F. Barely comes to 42V at 19F.
In defense of parallel living ๐ - if (IF) 3*195W can be wired in parallel with #8 cable, this is a good news because #8 MC4 cables exist and don't cost too much. There will still be parallel connectors but no rooftop box. But this still requires MPPT controller, because feeding 36V into PWM doesn't make sense.
OP - here is a curveball for you. Buy TS MPPT 45, #10 cable and 3*260W panels $234 each in series. String calculator shows max 104 Voc at 19F.
Total 780W and only $100 more than your planned 3*195W.
60-70% of time it will work as 600W, in the morning/evening/overcast/winter etc. (Your planned 3*195W would work as 400W in those periods). At peak sun the controller will clip the output down to 45A/600W. Or man up and get TS MPPT 60 ๐
โMar-07-2016 09:00 AM
smkettner wrote:
Oh good now we are fighting over $6 :R
(this was my point from the start)
โMar-07-2016 08:52 AM
โMar-07-2016 07:41 AM
carl2591 wrote:
My main purpose of this post was not to find the cheapest way to do this install. I want to do the best with a budget in mind and using the most cost effective products of quality, like morningstar products.
I know there are other good lower cost products but when you read post of folks that do a lot of solar like my friend handy bob solar, you learn what is a good quality product at a good price and will do the best job for your batteries.
In reading the morningstar white paper on the difference between MPPT PWM on lower watts and voltage system the PWM is the best choice. On higher voltage systems the MPPT will out perform more often with lower sun angles.
โMar-07-2016 07:27 AM
โMar-07-2016 06:56 AM
smkettner wrote:
Even the parallel connectors will cost that much.
โMar-06-2016 07:10 PM
carl2591 wrote:
I do understand about the wire size and estimate only needing less than 10 ga which is most of the MC4 stuff. so the loss will be less than 1%
when I put a low temp of 19ยญยฐF in the string calculator, "they" came up with voltage at 50.52vdc which is over by 1.56volts when connected in series.
โMar-06-2016 06:51 PM
Salvo wrote:
Instead of guessing, let's look at what's needed.
The panel under discussion is 195W, Imp = 5.38A, Vmp = 36.2V. Three panels in parallel
Salvo wrote:
The OP wants to buy the cheapest panels on earth, yet you want him to purchase a $60 combiner box??? When a substitute box can be gotten for under $5?
