wa8yxm
Jul 03, 2019Explorer III
I don't know why they put the Converter on the Fridge breaker.
Myself I'd run a sub panel for the inverter (IN fact that is how my rig is wired) but in your case.. locate the converter and either disconnect the 120 volt in or add a switch in that line (A switch with a lockout so you can pin it off) I think the boondockers are stand alone converters so this should be easy.
I will keep the boondocker in place (Just turned off or ac disconnected) so as to have it when (not if) you need it years from now.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
