โMay-07-2020 09:01 AM
โMay-11-2020 11:49 AM
imgoin4it wrote:
Instructions on two different brands of refrigerators, , Frigidaire and GE, both say set the temperature of the refer at 37 and the freezer at o. I think they understand the temperatures as well as the appliances they manufacture.
โMay-11-2020 06:24 AM
MitchF150 wrote:
I still wonder about the temps of those that shut down their fridge while traveling and say they can go for "4-8 hours" when It's *80 outside and everything is still cold??
But, what is the actual temps?? If they are still no more than *40 after 8 hours, I want one of those fridges!! Ha, even my home fridge can't do that! ha, ha.. ๐
Mitch
โMay-10-2020 09:37 PM
โMay-10-2020 04:40 PM
โMay-10-2020 04:20 PM
โMay-10-2020 11:18 AM
โMay-10-2020 09:17 AM
imgoin4it wrote:
The recommended temperatures are: 37 degrees for the refrigerator and 0 for the freezer.
โMay-10-2020 09:09 AM
โMay-10-2020 07:56 AM
โMay-09-2020 12:46 AM
โMay-08-2020 10:27 PM
RRTom wrote:
. . . the temperature in the refrigerator was 39 degrees. I am operating it on electric. Is this in the "normal range"?
โMay-08-2020 03:59 PM
โMay-08-2020 11:09 AM
Old-Biscuit wrote:RRTom wrote:
I have a norcold refrigerator. Unable to supply the model number right now.
I had the motor home a/c units set at 75 degrees. Outside temperature was 72 degrees. When I went into the motor home at 7:30 AM, the temperature in the refrigerator was 39 degrees. I am operating it on electric. Is this in the "normal range"?
What 'temp setting' are you using? (1-9)
'3' then 39*F is within range
'5' then 39*F and ambient is 72*F---then cooling unit should be able to go lower then 39*F
'9' then you have REAL cooling issues.....thermistor, door seals, heat transfer, obstructed cooling unit tubing etc.
I had it at 5. I've since turned it up to 8 a few minutes ago. Freezer temp this morning was 9.
We are heading out in a few hours, and once we get settled again I will check both again.
39*F under what circumstances????
Lot more involved then JUST if temp is within range!
โMay-08-2020 10:53 AM
