โMay-20-2013 04:09 PM
โMay-21-2013 05:46 AM
cougar88nw wrote:
If the seal is not leaking and the grease looks great ( and there's enough of it) I would just re-install the hub, adjust the brakes and go camping.
I just repacked the bearings and replaced the seals on my 12 year old TT, the bearings and seals were original and still looked great but I figured it was time to replace the seals. I used Amsoil Synthetic HD(Moly fortified) wheel bearing grease, it exceeds Dexter's specifications and because it's synthetic I feel comfortable going a little longer between inspections and repacking. This is only my second time repacking and the grease and bearings looked new. I don't have the EZ Lube axles.
If you need to repack or replace the seals, repack bearings, the bearing packers listed below do a better job and less mess too.
KD Bearing Packer
Lisle Bearing Packer
Be sure you don't over tighten the bearings if you do repack them. Best way to do this is to repack the bearings, replace the seal, apply a thin layer of grease on the spindle, re-install the hub (on the spindle), install outer bearing, washer, nut, hand tighten with pliers-channel locks-adjustable wrench-etc, spin the hub a few times, hand tighten the nut again, spin the hub again. After all that back off of the nut until the cotter pin slides into the hole on the spindle, most of the time you can actually rock the nut back and forth a little after the cotter pin is installed.....you don't want it to be too tight. Install the dust cap and spin the hub a few times, if you did it right, there will be a little back and forth play when you grab the hub/drum on either side and wiggle it. This play is more noticeable if you install the wheel and wiggle it while the wheel/tire is off the ground.
โMay-21-2013 04:37 AM
โMay-20-2013 11:36 PM
โMay-20-2013 11:12 PM
โMay-20-2013 10:26 PM
โMay-20-2013 07:01 PM
352 wrote:Mont G&J wrote:
I like and use the E-Z lube method.
I predict, the inexperienced without some mechanical knowledge attempting to repack wheel bearings will cause more harm than good and that will lead to an early bearing failure.
Clicky: Best method for the inexperienced.
When you are not educated on subjects sometimes you pay the price.
โMay-20-2013 06:34 PM
โMay-20-2013 06:29 PM
โMay-20-2013 05:44 PM
โMay-20-2013 05:32 PM
TLLOYD wrote:
Putting my mind at ease for sure. Should not be a tough job so I will tackle it before I leave to the river this weekend.
Next question, If I want to replace the seal or if for some reason I need a bearing, where do I get these parts? (auto parts store or direct from manufacturer)
Is there a name stamped on the axle somewhere that I would need to reference to get the right size seal, bearing or lock washer?
Thanks for the reference on doing this with your dad. I recall my dad with a wad of grease in his palm re-packing the trailer bearings when I was young. It was good to talk to him after reading this forum to get his advice and make him feel important as always.
โMay-20-2013 05:17 PM
โMay-20-2013 04:44 PM
โMay-20-2013 04:33 PM
โMay-20-2013 04:32 PM
