โSep-13-2015 10:25 AM
โSep-14-2015 04:20 PM
Terryallan wrote:
I read it as 'inside lights'
You read it as 'running lights'
Hey OP.....which lights? :B
โSep-14-2015 06:45 AM
Old-Biscuit wrote:opnspaces wrote:
The lights are separate from the battery so that parts sounds like a grounding problem with the tow vehicle. I'm betting your umbilical ground isn't working. It's an easy check, chock the trailer tires and turn on the truck lights. Now use the tongue jack to lift the tongue off the ball and see if the lights go out. Or if you don't want to use the tongue jack just hook the umbilical and use a jumper cable to ground the trailer to the tow vehicle.
As far as the battery being dead it sounds like your disconnect didn't disconnect and you had a dead battery. The tow vehicle running for a few minutes finally put enough charge into the battery to get the jack working.
โSep-13-2015 09:02 PM
โSep-13-2015 08:48 PM
โSep-13-2015 04:37 PM
โSep-13-2015 03:08 PM
โSep-13-2015 12:37 PM
Old-Biscuit wrote:That's what I was thinking.
Trailer battery was sucking up everything that little charge line thru 7 pin could supply........5 minutes later battery had a minimal surface charge that lights could work.
โSep-13-2015 12:31 PM
โSep-13-2015 12:07 PM
โSep-13-2015 11:50 AM
โSep-13-2015 11:40 AM
โSep-13-2015 11:37 AM
