doughere
Nov 03, 2013Explorer
I have 2 60 watt panels tied to the battery through a small PWM controller, and have the charge wire from the truck connected whenever we're on the road, now and then need to run the generator leave all tied in. Also have a 100 watt portable panel without a charge controller, when I use it I just throw it in the mix too. Whoever has the highest voltage does the most work. Never had any problems.
Regards,
Doug
Regards,
Doug
