NinerBikes
Nov 04, 2013Explorer
christopherglenn wrote:
Not much. The 120 watt panels at 17.2 volts generate just under 7 amps, 225 AH @ 75% you are down 56 amps. In theory you will need 8 hours of direct sunlight just to fill the bank. With the fridge and propane detector running at the same time you are likely closer to 10 hours. On a cloudy day you may be seeing 30% output - which doesn't matter, as there isn't 10 hours of daylight anyway.
Where things get exciting is if you are closer to 90% SOC, then several hours of clear sun can get expensive.
How many amp hours do you think that fridge and propane detector draw in a 24 hour period?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
