โNov-16-2016 04:02 PM
โNov-18-2016 09:00 PM
โNov-18-2016 08:08 PM
โNov-18-2016 07:24 PM
MEXICOWANDERER wrote:
Your charge path is defective.
โNov-18-2016 06:57 PM
pianotuna wrote:
Hi Phil,
I have two solenoids, each with a 200 amp rating. It would seem doubtful to me that both had failed at the same time.
pnichols wrote:
Don,
Does you RV connect the alternator to the coach batteries with just a 12 V high current solenoid like in my Class C?
If so, you might want to measure the voltage on both the input and output side of the solenoid when the coach batteries are low and the engine is running?
Obviously those voltages should be identical. If not, the solenoid contacts have turned resistive, which could explain why your RV battery bank isn't getting charged as it should be with several hours of driving.
I've had this happen twice in the 10 1/2 years we have had our Class C.
โNov-18-2016 01:52 PM
โNov-18-2016 01:45 PM
pnichols wrote:
Don,
โNov-18-2016 06:45 AM
โNov-18-2016 05:46 AM
pianotuna wrote:
Hi all,
I'm currently staying ahead of the snow! In fact, if I'm lucky I won't see it at all.
Overnighting at Harmony, MN or possibly farther south.
โNov-17-2016 08:55 PM
โNov-17-2016 07:44 PM
โNov-17-2016 06:34 PM
โNov-17-2016 06:24 PM
โNov-17-2016 05:58 PM
mchero wrote:
Just like the guy that was speculating my isolator relay was getting 16 volts!
LOL
mchero wrote:
You think I should also be equalizing the chassis batteries at 16.2 as well?
Another reason I'd like to disable that solenoid.
โNov-17-2016 05:25 PM
โNov-17-2016 05:16 PM
pianotuna wrote:
The only change was to the AGM jars for the house. I noticed lower charging immediately--but put it down to the old tired Marine jars (9 years old).
