- hellbird503ExplorerWell, I ended up using a metal coat hanger and heating it a little bit with a lighter and used it to melt the ice in the inside opening, then went outside and blew back through it, it worked. Thanks for your help, Dave
- rockhillmanorExplorer IIII don't have the screen tube at the end of mine. It's flat and the opening is separated into 2 thin openings that clog all the time.
I found the end of a metal shishkaboob skewer fits right up there and clears it right out. Go figure. - downtheroadExplorerNot real high tech, but I just took the perforated cap off the end, put my lips on the tube and blew as hard as I could...kind of a back flush thing. It worked.
- rockylarsonExplorerMy drain tube (Dometic) extends several inches from the chassis in front of the rear wheel. (below the refrig) It terminates in a small perforated plug. The plug twists out and reinserts easily. That is where I figure any stoppage would occur. If further up I would start by applying suction to the tube and if that didn't work perhaps some low pressure. Good Luck
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
