Dutch_12078
Aug 16, 2019Explorer II
Check the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
