- HamnetExplorerDustyr, good idea, I will try that.
- Dusty_RExplorerMany years ago my inlaws had a pick-up camper that had the same problem. My father-inlaw used a piece of furnace air filter to prevent drafts to the water heater, it let air in but prevented drafts that blew out the pilot.
Dusty - HamnetExplorerMy refrigerator is on the recall list. I take it in thursday for the recall fix and I am having them do a refirigerator service while it is in there. I think I will cover some of the exterior venting while I travel an see if that works.
- beemerphile1Explorer
ksg5000 wrote:
It's a problem you read on this forum all the time so "servicing the fridge" may not be the solution....
True, but it certainly should be the first step. When looking for solutions the first step is to make sure it is working as good as when it left the factory. Then you start making homebrew modifications. - ksg5000Explorer IIIt's a problem you read on this forum all the time so "servicing the fridge" may not be the solution. Try closing off a portion of the outside vents - probably won't take much to change the wind deflection. Just my 02.
- old_guyExplorerwhy don't you just turn it off and put reusable freezer packs in the frig to keep things cold. we do and have no problem with keeping things cold
- HamnetExplorerThanks everyone. You are probably right on the pilot light versus igniter. Now that I think a little more it is an igniter. I will look into all the responses you gave me. It has been a long time since service. I just put back in storage but will go get the info and look at the unit. I may need to continue this thread after getting more product info.
- beemerphile1ExplorerLike stated it is extremely unlikely that you have a pilot light. If the DSI isn't working correctly to keep the refrigerator lit, you need to service the burner assembly and chimney. When was the last time this annual maintenance item was performed?
You did leave the LPG valve open, right? - bob213ExplorerI believe part of the "fix" on the Dometic recall was a larger wind deflector. I bought a 6X10 piece of metal flashing and cut it to fit. It blocks wind from the burner orifice and I have no more blow outs while driving. It may not have a pilot light but it would blow out the flame without it.
- n7bsnExplorerI haven't had a refer with a pilot light since the 91 Fleetwood, the 99 Northwood had an auto-ignite refer.
But back then, ya, it could blow out on the road.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
