DD716TED's avatar
DD716TED
Refrigerator movement
Help..on road and Domestic refrigerate has moved about 2 inches out from
Wood mounting cabinet..tried to slide it back in with no luck..is out far enough to stretch wires in back very tight. Cannot push back in from front..rear mounting screws pulled from plywood opening floor. Ideas / help before we move to next campground..thanks
  • Thanks to all..emptied refrigerator and straightened it out..slid right back in. Reinstalled screws and installef missing screws that were left out when repair man replaced cooling coil system...
    How did it turn out?
  • Did the top of the fridg pull out as well?
    If not, the fridg may be in a jammed position (use flashlight to look under frig from the backside to see if the rails are sitting flat).
    If jammed us, I would work from the backside. Remove screws. Try tying a clothes hangar in each hole to provide "handles" to pull back with (may need to lift up at the same time). Use bigger replacement screws at the rear.
    If it is like mine, there should be screws holding down the front (bottom of the door and behind trim.
    Hope this helps!
    Pat
  • Your going to have too remove those screws in the back
    Then put something under there for it to slide on
    Plastic wedges ? Plastic strips, etc..
    Somebody pushes from the front
    While another trys to wiggle it from the back
    Do NOT PULL on the cooling unit you need to grip the sides of the fridge for wiggling and pulling from the outside hatch
    Yeah I know clearance problems
  • Which model Dometic is it? With model number, can find the installation manual and link it here so you can see what to do for now until you get home. Or you can Google that if you have enough internet access.
  • Sit on the floor in front of unit with legs bent. Brace against the slide, dinette, or what ever is in front of the frig. and straighten your legs to push up and back on frig. Best to make sure nothing is digging into the wood in back while you push in front. Maybe put a plastic knife with butter on it or similar slim slippery item under the rear edge to get it to glide easier.
  • My Norcold was HEAVY. They do not slide easily. To fit, I had to have 2 people. One on each side.
    "One, two, three, LIFT (push / pull)"
    Caution with your back :)
    PS: "Lift" means to push upward. I removed the freezer door (not really necessary however) to gain purchase. The cooling unit should not be gorilla'ed. Be gentle.
    Why wasn't two sturdy LAG SCREWS used in the mounting feet on the cooling unit side of the refrigerator? Something is wrong with this picture. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
