Doing some maintenance and discovered the screen in the refrigerator roof vent is crumbling in my 2006. The original screen appears to be aluminum and time has taken its toll.
The original screen was molded into the plastic of the vent and an easy fix isn't obvious to me. The plastic part is glued and screwed to the roof so replacement isn't desirable.
Have any ideas?
I need screen and a means of attaching it. The original mesh was substantially larger than window screening but small enough to keep mud daubers and the like out.
Edit:
I see there is a replacement screen for Norcold vents, unfortunately mine is Dometic.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
