melandme
Aug 31, 2021Explorer
Refrigerator won't light at higher elevation
This has happened on 4 trips, in 2016 in the North Carolina Mountains and in Wyoming and Montana and in 2019 and 2021 on trips to Colorado.  The igniter sparks and there is gas, put it doesn't light.  You can light it by hand.  All of the other gas appliances work fine.  What is odd is that when you get out of the mountains it works fine.  For 3 years it lit every time we switched to gas.
I know the air has less oxygen at elevation, but wouldn't the water heater and stove have the same problem lighting. The only thing I can see is the refrigerator is more exposed to the outside. Anyone else had this happen?
