Remote entry question
mchero
07 Fleetwood Discovery owner.
Noticed range on remote keyfob not good. I inspected the receiver under the center console and discovered the black antenna wire hanging out of the receiver broken. Looks like it was cut/broke during assembly of the dash.
Can someone with like setup measure your black antenna wire too get the total inches.
Also, the actuator in door has a rubber dust boot falling apart. Is their a place where i can order parts?
Thanks
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
16 REPLIES 16
mchero
Did look under American coach but did not see it.
Googled part # and found one on GreedBay.
https://www.ebay.com/i/233140283269?chn=ps&ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F1...
Looking at the photo you can see the black antenna wire... Mines about an inch long. It was cut when the frame for the dash was installed. It still worked but had a short range.
Yes a production issue that I was aware of shortly after purchase. Just figured its time to correct. A simple fix, just needed a rough length
Thanks for the posts.
Robert McHenry
dougrainer
mchero wrote:
dougrainer wrote:
https://www.trimarkcorp.com/en/eask.aspx
Thanks Doug
Odd that Fleetwood is not an OEM.
You look under American Coach
mchero
Thanks Doug
Robert McHenry
dougrainer
SaltiDawg
mchero wrote:
Not looking to talk to Fleetwood.
I am simply asking if someone with same setup to measure the antenna.
And you've been so nice about the posted suggestions.
mchero
Robert McHenry
B_O__Plenty
Fleetwood that manufactured that unit is no more. They went bankrupt and closed years ago. Somebody else bought the name but they won't be of much help.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
wa8yxm
If you know the operating frequency of the transmitter I can work it out for you. if you are near me I have a device that MIGHT measure it. (So do many hams_ beyond that I can't help much
in inches about 2775/(Operating frequency in MHZ)
Or.. twice that. Those are the only two proper lengths.
MrWizard
Moderator
Moderator
i would just splice on more wire to the antenna, and see if that fixes the problem
I can explain it to you.
1997 F53 Bounder 36s
mchero
Keyfob OK, just short range due to the short antenna.
Robert McHenry
BB_TX
I recently changed the battery in my 2012 truck key fob due to it getting weak. New battery and much better range.
Beverley_Ken
Did you try changing the battery in the key fob. The fob I normally use is getting weak, I have to be within 10 feet of the cab (E450 chassis) before I can unlock or lock the door. Doesn't work from the back bumper of the MH. The other 3 fobs work normally, 50-100+ feet away.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
mchero
MDKMDK wrote:
Did you try an internet search for Fleetwood RV dealers? Perhaps they might know the answers to your questions.
https://www.fleetwoodrv.com/locate-rv-dealers
Fleetwood dealer would be the last place I'd go.
In due time a reader will see the post and respond
Thanks for the reply.
Robert McHenry
mchero
maddog348 wrote:
12 yr old unit ~~ just discovered an assembly issue ??
Yes indeed a 12 year old "unit"
No I did not just discover
Thanks for the informative responce.
Robert McHenry
