TriBeard
Aug 24, 2020Explorer
naturist wrote:
Assuming all panels are the same voltage, a 30 amp controller should be able to handle all 240 watts of panels. Put them all in parallel, and it should be fine. 240 watts at 12 volts is 20 amps, well within the controller’s capacity.
Of course, upgrades are always possible. But the simplest is just adding the 200 watts.
Judging by the spec sheets I was able to find, the voltages are within a volt or two of each other, but they're not identical.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 24, 2025
