tmmar
May 16, 2014Explorer
Tom,
There are 4 screws on my Dometic AC- one on each side toward the rear and 1 on each side in the front of the AC. Not sure if the Coleman is much different. Once you remove the screws you should be able to see pretty much everything that you would need to look at. Not all that hard to do.
Good luck,
Tom
Good luck,
Tom
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
