DReisingerExplorerMar 01, 2017Removing old sealantI am replacing the ceiling vent in the fiver with a Maxxair Fan, the instructions say remove ALL old sealant from flange. Is there any thing that will make this go a little easier?
gboppExplorerMar 01, 2017A plastic putty knife and heat gun will do the job. Just be careful with the heat gun, you don't want it too hot.If you have a larger area, consider a Fein Multi-tool or the Harbor Freight knockoff.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
Related ContentStaple RemovalRemoving built up sealant?Removing factory silicone sealantSealantTailgate Removal
