BFL13
Jul 01, 2021Explorer II
S Davis wrote:
So I just retook the readings for my 50 amp Redarc
Batteries at 80% 12.5 +-
13.8 volts truck idling
28 amp draw at under hood breaker
25’ 1/0 DLO both positive and negative to Redarc
13.6 volts into Redarc
14.4 volts out to batteries @ 24 amps
I remember in a past test how the truck's voltage fell off once I reached a certain demand on the truck battery by increasing the load on the inverter clamped to the truck battery (truck idling). It held its voltage near 14v up to a point, then the dash voltage needle started to tremble and then it fell off to the left. The truck's system can only take so much! I expect it is not linear.
I wonder what the numbers would be when output is 50 amps at 14.4v. What about the higher demand pulling the truck's battery voltage down where that may not be linear?
I am thinking the 24 vs 28 amps at half rating might not be just 50 vs 58.3 amps. You would need the house batts down to more like 50% instead of 80% going in to test for that.
The input watts use the voltage at the DC-DC end after voltage drop from the truck's end, but that truck voltage comes down too.
We have been looking at the efficiency of the DC-DC, but there is also the non-linear ? efficiency of the alternator. Efficiency of these electronic things seems to be somewhere on an "efficiency curve". What if the curves for the DC-DC don't match the shape of the curves for the alternator, so you don't get what you expect just from calculating voltage drop etc for the DC-DC unit?
Guys who know these things will be able to confirm or deny this whole notion and perhaps explain more how it actually works.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
