โMar-09-2014 01:22 PM
โMar-10-2014 02:05 PM
โMar-10-2014 10:30 AM
moonlightrunner wrote:
FYI... The friends who did all the work on their popup had no problems from using those materials. The "all purpose" cement stated right on the can it was for ABS. The repairs lasted for years and was still holding when they sold the unit (that would be 2003 - 2009). Once a repair was made it held. And they camped year round in freezing temps and snow in that popup.
I think the Plastic Dip is neat. Have you looked at https://www.dipyourcar.com/home.php?? Apparently if you don't like how it turns out or you change your mind, you can just PEEL IT OFF!! That is just amazing. I'm considering doing the aging wheel covers on my RV. After all, if I don't like it, I can just peel it off. So many colors. So cool.
โMar-10-2014 10:19 AM
โMar-09-2014 11:15 PM
chooochoooboy wrote:
Trail Lite used abs plastic to trim out bottom edge of exterior including the rear "bumper" that holds the sewer hose. My right front corner piece got damaged and I need to repair it since R-Vision (Trail Lite Mfg.) is out of business and parts are not available as far as I've been able to determine. Has anyone had experience repairing abs???can I use fiberglass cloth and bondo?? Any help will be greatly appreciated.
โMar-09-2014 07:11 PM
.... http://www.freewebs.com/schinskeapache/remodel.htm
Reese Dual Cam Straight Line HP Sway Control
โMar-09-2014 05:34 PM
โMar-09-2014 02:50 PM
