LittleBill's avatar
LittleBill
Replace Ladder stand off nut
has anyone replaced these? over half of mine are rusted out. I am trying to think of a way to replace all of them without removing the screws in the fiberglass, but I am assuming this is not going to be possible..
link of what i bought
  • I have R&Rd my ladder, and IIRC, the only way to remove those nuts, is from the back, requiring removal of the standoff. Even then, it seemed they were locked in. I didn't need to replace any, and glad of that!
    Jerry
  • pigman1 wrote:
    Not sure which one of those you're concerned about. The Tiffin ladders are backed up by a molded in steel sheet behind the fiberglass, so removing those screws is fine as long as you don't "ham hand" them going back in. Don't power drive.
    A line in your signature with your rig info (brand, model, year) helps responders tailor their comments to your rig.
    its a 2000 chateau sport, but is that the procedure the entire ladder has to come off? there is 0 video's or docs on the replacement procedure
  • Not sure which one of those you're concerned about. The Tiffin ladders are backed up by a molded in steel sheet behind the fiberglass, so removing those screws is fine as long as you don't "ham hand" them going back in. Don't power drive.
