2manytoyz's avatar
2manytoyz
Mar 06, 2019
Replaced the carburetor on an Onan 5500W generator - Video
Bought a new carburetor on Amazon. Little tricky to connect the throttle linkage and return spring, but otherwise a pretty simple job, only basic tools needed. No more rough running, or quitting issues.
For those considering the task, I've put a video online so you can determine if it's a DIY task for you too.
https://youtu.be/DUEthYuKGMk
I'll eventually disassemble the original carb, see if I can find what the problem was, clean it, and keep it for a hot spare. Definitely something that can be swapped at a campground. FWIW, Onan doesn't offer a rebuild kit. We have trips planned soon, and it's already been in the mid 80s here in FL. The dash air doesn't work well enough on a long trip, so I needed a working generator to run the roof top units.
Worth every penny, runs like new!
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
