- Trailmanor13ExplorerWell I used the 2 hole saw method this morning and it took maybe a minute and a half.
This was a swing tongue, so I took it completely off and laid it upside down on the lawn.
It would work just as well on a regular tongue except you would be on the ground drilling up. - BumpyroadExplorer
profdant139 wrote:
trailmanor, I like your idea of cutting little slots all around and then bending the uncut pieces to enlarge the hole. It's not elegant, but it gets the job done. When you are done, you can clean up the little spikes and shards with a round metal rasp.
And then if the raggedy edges of the hole are still visible after you install the new jack, slap on some caulking around the perimeter to hide the mess. ;)
bending that thick steel material will be extremely difficult and if that works you will end up with a jaggedy mess unless you spend hours with that rasp.
from reading all of the responses/comments if I was to do this I would bolt a metal plate using existing 3 bolt holes under the opening for the pilot hole, get a decent hole saw of the proper size and drill out the desired hole. easy peasy, no hours cobbling things up with a rasp etc. end up with a smooth opening.no mess, not needing caulking. :)
bumpy - Bill_SatelliteExplorer IIDepending upon your hole saw chuck, you may be able to mount a 2" hole saw inside the 2 1/4" hole saw and the 2" becomes the center guide for the 2 1/4". I recently did this to enlarge a 2 1/2" hole to 3" but I had a bit more clearance.
- profdant139Explorer IItrailmanor, I like your idea of cutting little slots all around and then bending the uncut pieces to enlarge the hole. It's not elegant, but it gets the job done. When you are done, you can clean up the little spikes and shards with a round metal rasp.
And then if the raggedy edges of the hole are still visible after you install the new jack, slap on some caulking around the perimeter to hide the mess. ;) - Cummins12V98Explorer III
ajriding wrote:
You can only use a hole saw if there is a center. The hole saw has a small drill bit in the center, maybe 1/4 in or so in size. That 1/4 bit is the guide that keeps the big circle saw blades in place. Without that center bit, or without a center to the hole, there is no way to use a hole saw, it will just scramble all over your work space.
You can weld a plate, then drill through the plate and the part you want to enlarge (but lets face it, a guy who can weld is not asking an RV forum how to drill a hole in metal), or
maybe attach a piece of wood there to act as a center point for the saw, wood will be easier to drill through than another layer of metal too.
The easiest is to just grind away. This sounds like a lot of work, but really should be the easiest. I personally do not have a grinder that small that would fit inside a 2 inch hole. The link given for HD's grinder will not work either - too big.
I have used a file to make this kind of hole bigger, but 1/8 inch all the way around (makes it 1/4 bigger) will be a lot of hand work on steel.
Cutting slots and bending will make a mess. This would work on thin metal, but trailer frame metal is too thick.
Consider that a jack is not a precision instrument. Maybe you dont need to make a perfectly symmetrical circle in the center-line of the trailer. Make your cut/grinding off-set, to the front, to the rear or even to the side, so just grind away half and when the new jack fits then slide it in. Hand grinding will not result in perfection. Make a circle mark with a sharpie before you begin so you have reference as when you grind you lose the original circle that was your starting guide.
No pilot hole needed with my method. - BumpyroadExplorer
mobeewan wrote:
No need to weld a plate on to use to center the hole saw. Do like Cummins12V98 says. Clamps will work, but you can also add bolt holes to so it can be bolted down using the bolt holes for the existing Jack.
yep, much easier to bolt it using existing hole pattern than clamping/welding etc. and when you get done with the hole saw your jack won't look like a cobbled up mess like some other suggestions would.
bumpy - mobeewanExplorerNo need to weld a plate on to use to center the hole saw. Do like Cummins12V98 says. Clamps will work, but you can also add bolt holes to so it can be bolted down using the bolt holes for the existing Jack.
I did something similar when replacing both crummy uncovered gravity and city water fill connections on my trailer with ones that had lockable doors. I needed larger holes to install them. I cut a small square piece of half inch plywood to use as a template. I used a 4 inch hole saw to cut a hole in the template. I then mounted one of the hatches to the template using the screws needed to mount it to the side of the trailer. I then removed the hatch and screwed the template to the side of the trailer over the existing hole. It stabilized the hole saw while I cut the first hole through the side of the trailer. I then removed the template and lined it up over the next hole keeping it in line with the first hole, screwed it to the trailer and cut the second larger hole. Worked great.Cummins12V98 wrote:
Drill a 2-1/4" hole in plywood or steel and clamp over existing hole centering the template over existing hole. Drill away, ez-p-ze. - FreelanderExplorer III believe you bought the wrong jack. They come in two different sizes depending upon the weight capabilities. Before cutting or grinding, I would check to see if the proper size jack assembly is available.
- BurbManExplorer IIII would be inclined to send it back and order a BAL 29025B, same specs as the Curt but has a 1-7/8" OD jack tube. Problem solved.
- pigman1ExplorerAn angle grinder with a carbide bit like Carbide burr bit.
I've used these numerous times for enlarging holes. A grinding stone on a drill will wear down quick and take a lot longer.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
