Old-Biscuit
Dec 28, 2017Explorer III
ASME Propane tanks fall under the NFPA Jurisdiction which 'recommends' that the Pressure Relief Valve be replaced every 10 years.....but that us only a recommendation NOT a requirement.
Only time an ASME tank HAS to be replaced is it damaged from an accident/fire etc or rusted thru.
Clean up surface rust, repaint and replace relief valve---good to go.
And I would write a bad service review on that rip off joint.
They should be able to provide the documentation showing the requirement to replace tank at 10 years......hahahaha
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
