Baja_Man's avatar
Baja_Man
Replacing Plastic Water Tank Fittings - How is it done?
The TH I am purchasing has a cracked fresh water tank fitting. It is the white drain fitting that has a female threaded section where a 90 degree elbow is attached. Fitting/elbow thread are approxima...
